how was the EXE launched?
Hi all,
This is a Windows question : is there a way to know from within my app (when it runs as an EXE) if it was launched by the user (clic on the EXE file) or if the app was lauched by the OS because it is in the startup?
Thanks in advance for any help
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,219 Views)
Why not ask a car question while you are at it?  😉
Bill
CLD
(Mid-Level minion.)
(3,214 Views)
Accepted by TiTou
I don't know if there is, but you could probably configure the shortcut to pass an argument as part of the call and then check in your code whether you receive it or not. I don't like this because it relies on a hidden configuration in the shortcut, so I would probably prefer a bat file rather than a shortcut.
___________________
Try to take over the world!
(3,202 Views)
It makes sense! Thanks for the batch + argument idea.
Epictetus
Antoine Chalons
(3,197 Views)
It's possible to do something similar to this without modifying your LabVIEW code - if you look in task manager, under processes - there is a column (hidden by default) called 'command line' - it shows the command line arguments that were passed to the application when it was launched. If you set your 'start up' application to launch with a command line (e.g. using a shortcut / batch file) you can then see this in the task manager.
You can probably get the command line arguments of another process using the .NET process library.
(blog)
(3,166 Views)
