hp4142B VS2 not working?
Hello everyone,
I have developed a Labview driver for HP4142B, where I have 4 MPSMUs units and 1 VS/VMU unit. In this VS/VMU init, there are the following outputs: VS1, VM1, VS2, VM2.
According to the HP4142B manual, the channel # for VS2 is 2n, where n is the slot # where the VS/VMU unit is installed. In my case it is 25 (n=5).
However, when I try to output a voltage through VS2 I measure nothing, while I get an output with VS1 (installed in the same slot).
So, do you have encountered such an issue? Is it a software or hardware issue? Can anyone help?
Thank you a lot.
Florian
Message 1 of 1
(2,195 Views)
