hp837xx_32.dll is missing from the package, drivers won't work.
Hello, I am currently trying to use a signal generator (HP 83711B) with LabVIEW 2021 sp1(Windows 10). I download the driver HP837xx and unziped it in intrs.lib folder wich is what I always do. The problem is that when I try to use this library it keep asking to find hp837xx_32.dll file wich is not there at all. Can someone please help me with this ?
This is the link to the driver :
Agilent Technologies / Keysight Technologies hp837xx Signal Generator - IEEE 488.2 (GPIB) Driver for...
I also downloaded Keysight connection Expert. The SinGen is recognized and I can Write and read from it.
I really need it to work on my LabVIEW. is there any solution ??
thanks.
(1,239 Views)
You probably want to install this driver here also: https://www.keysight.com/zz/en/lib/software-detail/driver/83711b-83712b-83731b-83732b-signal-generat...
That LabVIEW driver is just a convenient wrapper for the IVI driver from HP/Agilent/Keysight
Rolf Kalbermatter  My Blog
(1,218 Views)
I've already tried this one but it says my pc can not run these types of files.
(1,195 Views)
It seems a very old driver (2004) and absolutely certainly only 32-bit.
It may be necessary to put the file somewhere on your system (HD) and change its compatibility settings to Windows XP or earlier. In Windows explorer right click on the executable installer and select Properties->Compatibility.
And of course you will need to use LabVIEW 32-bit for this. The installer certainly won't have 64-bit versions of this DLL.
(1,189 Views)
