html, unable to change list font
Dear Madam/Sir,
After trying multiple things I still couldn't figure out how to fix this issue.
I'm trying to make the text before a Append list Bold but the text in the list not.
As shown in the code ( which is in the attachements) i declared different fonts to both the list and other strings
Is there any solution to it?
Regards Koen
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
Message 1 of 10
(4,455 Views)
Hello Koen,
Is there a specific reason why you are using the "Set Report Font.vi"?
The help explains that this VI will set the font of the whole report and not of one subsection.
I think the "Append User Formatted HTML to Report.vi" might be more useful in this case.
Can show us what your final text should look like?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 2 of 10
(4,406 Views)
Thank you for your answer.
Actually I don't have any experience in HTMl whats-o-ever.
It should look like this, i also included the vi itself
Message 3 of 10
(4,402 Views)
Did a little HTML training on internet.
Fixed it using append html
vi in attachments if someone is interested or if there are any improvements
Message 4 of 10
(4,384 Views)
attached VI might help you.
please check that.
Message 5 of 10
(4,372 Views)
Accepted by KoenR94
Hi Koen,
Updated VI.
Message 6 of 10
(4,369 Views)
Woow thank you for your help.
Could you please attach the "HTML image.vi"?
Thanks in advance!
Message 7 of 10
(4,364 Views)
Hi koen,
HTM Image Vi is from from LabVIEW only.
browse to the icon loaction on control pallete
Connectivity -->Internet --> CGI --> HTML --> HTML Image
the location in the HDD is "C:\Program Files\National Instruments\LabVIEW 2011\vi.lib\addons\internet\http\html2.llb\HTML Image.vi"
any way I have attached the VI.
Message 8 of 10
(4,352 Views)
library file .llb
Message 9 of 10
(4,351 Views)
you added the wrong library file Smiley Surprised
searched the internet for the vi but couldn't find it
Message 10 of 10
(4,327 Views)
