hysteresis anyone?
 I have two signals from two sensors, these will be put together to calculate the hysteresis. Is there anyone that can help or tip me of a complete programme or something to work with?
Appreciate all help!
Stefan in Sweden
Message 1 of 16
(4,465 Views)
i don't know if there is existing function, but can you give us more details because it's not same complexity if :
1) you want to process on existing data ( you acquire an hysteresis cycle  an then analisys) or real time measure (analisys point afer point)
2) is it a physic hysteresis or electronical ? the output is aproximately 2 states ( ex 0-12V) or multiple (like magnetic hysteresis)
do you have a file of samples points to give us an idea of what you want to analyse
Cordialy
tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
Message 2 of 16
(4,416 Views)
mistake , to kill
tinnitus
Message Edité par tinnitus le 04-06-2008 08:58 AM
Message 3 of 16
(4,416 Views)
hysteresis has a general meaning, it is not a function.
Please give us more details....
Message 4 of 16
(4,402 Views)
It is for a system that calculates the hysteresis between the two curves shown in the inserted file, this picture may clear things up. The sensors are: 1 pressure sensor that registers the output voltage, and one magnetic sensor that also registers the output voltage. I would like to display the difference between the upper line and the lower line. '
At the moment i have solved this issue by printing out 500 samples from the magnetic and the pressure soutput voltage into a .xls file that displays the difference (hysteresis curve). Is there a better way to solve this?
I hope this information solves our problem?
Best regards
S
Message 5 of 16
(4,371 Views)
I suppose you can say that it is electronical because its the output voltage that im interested in. I can give you an .xls file tomorrow to show you how this looks like.
Once again, appreciate all help I can get.
Best regards
S
Message 6 of 16
(4,369 Views)
I forgot to say, I have an DAQ unit that interprets the signals from the sensors. Maybe not so important for you to know?? 🙂 I'm an LabVIEW amateure. Thanks,
Best regards.
/S
Message 7 of 16
(4,368 Views)
It s just a details but x and y aren't inverted , it isn't stroke that depend of pressure ?
i take a look on what could be done...
I hope this information solves our problem? Smiley Happy
Cordialy
Tinnitus
Message Edité par tinnitus le 04-08-2008 10:41 AM
Message 8 of 16
(4,334 Views)
the stroke is of course dependent on the pressure.
Is there any more questions please let me know. Appreciate everything...
Stefan
Message 9 of 16
(4,315 Views)
hello,
here a very basic vi to measure hysteresis, it works only on clean outing signal because of simple detection (trigger function)
if not, try to filter or better to average signal
A details: your hysteresis seems to be slightly different at low and high level , here measure is taked at middle scale...
 you can change this by modifying "analyse point"
cordialy
tinnitus
Message 10 of 16
(4,263 Views)
