hysteresis anyone?
It says following when i try to open it: LabVIEW error code 9:VI version 8.5 is newer than version 8.2.1.
How do I solve this?
Thanks again,
Can't wait to see your programme 😄
/S
Message 11 of 16
(1,371 Views)
sorry i always forgot,
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
Message 12 of 16
(1,366 Views)
Hi again,
sorry to say this but I still get the same error.
Best regards
S
Message 13 of 16
(1,340 Views)
here 3 versions 8.2,8.0, and jpg in case it still doesn't want to open...
ps: by clean signal i would like to say monotone around trigger level
Message 14 of 16
(1,331 Views)
Hi again collegue 🙂
Could you explain the software you've developed?
The hysteresis must be presented with an graph from the values taken from the pressure- and 'stroke'sensor. Also would like to configure the samplingfrequency and the the number of samples.
What is the trigger function for each channel used for? I know that this triggerfunction is used in hysteresis but why?
S
Message 15 of 16
(1,208 Views)
Software is a big word,
I made a little example that give you an idea to use the basic "soushyster.vi"
that have to be adapted to your system.
Soushyster is a raw vi it search in Y values array  the two first indices of middles points and make correspondance
with X array to evaluate hysteresis ...
such as it, it make this one time one the only first periode of array
to explain graphicaly, it is easier, i look for max amplitude of Y that give me the dynamic, then i choose to work on middle point of it (/2),
the trigger fonction give me  the two  indices of Y array  corresponding to this middle point. then using indices to know values of X corresponding ...
vi can return negative hysteresis, it not important, just take absolute value.
Best regards
Tinnitus
Ps: do you still have troubles opening (my) vi , 8.0,  8.2 ?
Message 16 of 16
(1,180 Views)
