i am able to get color images in the continues shot but when i try to snap a color image which i need for my processing i get only a monocrome image
I have been using lv_vfw.llb VI's for grabbing images from a CREATIVE WEB CAM ,i am able to get color images in the continues shot but when i try to snap a color image which i need for my processing i get only a monocrome image ,i have been trying to play around with the RGB weightings but i am unable to get a color iamge,it shall be of great help if you could help me in doing this as it is urgent for me.Thanks for your help.
(2,624 Views)
vicky,
I am unfamiliar with the lv_vfw.llb, and have not used it before. However, I noticed that you stated that you are able to grab in color, just not snap in color. If this is the case, why not just perform a grab and then extract a single buffer from this grabbed data, which would likely be in color? This seems like a possible solution to the issue that you are seeing.
Other than that, I really don't know enough about the lv_vfw.llb to be of much help on this issue. Hopefully another member of this forum will be able to assist you with this software.
Jed R.
(2,624 Views)
