replace arrary subset is too slow
I find that the function "replace arrary subset" is too slow. Please see the attached VIs. Could some one tell me why? Thanks!
(2,983 Views)
"Replace array subset" is typically very fast.
Your main problem is the use of global variables inside a loop. I cannot test because I don't have a data file, but the attached modification should speed it up a bit. It limits the constant reading and writing of globals.
You might also consider reading all records outside the loop, replace the while loop with a for loop, and autoindex on the array of records. You should be able to calculate how many records are in the file from the file size.
(2,983 Views)
Reading a global always makes a copy in memory. A brief description why globals inside loops are slow can be found HERE.
You might also want to read the NI application note about LabVIEW Performance and Memory Management.
(2,983 Views)
