i am trying to reset a serial device through serial port ,MAX is able to do it but the same command is not working in labview
max can do it but labview cant
(2,991 Views)
I'm sure LabVIEW can but maybe the way you wrote the program is the problem. What are you using - VISA or the old serial? Are you sending a teremination character if one is required? Attach your code so someone can look at it.
(2,991 Views)
- Run NI Spy Tutorial
- Reset the serial device in MAX
- Run the LabVIEW code
- Post the *.spy file.
The spy capture will show any difference in function calls to the driver.
(2,991 Views)
