i can't control some function vi via the web
Dear all,
This is one of the testing vi i write, but i got some problems when i
try to control (get start) the vi on the client side (via the
internet) i found two functions doesn't work. But it can work properly
on the server side.
The vi is about testing the target circuit by HP34401A.
And the missing functions on the client side are:
1.the create and open of a txt /excel file to log the data needed(at
the begin of the progam).
2.the saving of Waveform Chart as jpg.
Server: Test.vi
Labview 6.1(FDS)
Client: Only IE with TCP/IP
NOT installed LV
And here is the test.vi. Can anyone tell me how to modify it to make
it work on the client side?
I need to hand on my final year project very soon, so ple
ase help me.
Thanks~~
(2,479 Views)
thanks all~
i've got the solution~
to slove the problem,i set the default path of the txt/xls file and
the jpg file
(2,479 Views)
