i have a problem in the path!!
when i launch my 1st vi:0-new motdepasse.vi  the 2nd window opens,but when i click validate in this window the 3rd one "2-nouv liste item.vi" don't open.
i think the problem is in the subvi"OUVRIR_VI.vi" which don't allow me to open more than 2 windows or something like that.
if anyone know the solution i'll be really very grateful.thanks
(2,633 Views)
From what I can tell you are simply trying to open up a different VI and run the front panel contained within it?
If this is the case then a much simpler solution to run the VI would to be to simply replace "OUVRIR_VI.vi" with the relevant vi be it "nouv page.vi" or  "nouv liste item.vi".
Then change the settings in the right click menu item "SubVI Node Setup.." to the appropriate settings.
(2,618 Views)
Accepted by achfire
Your ouvrir VI has "Wait until done" set to True. So it waits until the called VI terminates and can't be called again until this is the case.
Try setting "Wait until done" to False.
(2,584 Views)
Make sure your OUVRIR_VI.vi is set to be reentrant (shared).  It is likely that your first call is blocking the second and you are stuck in gridlock.
GCentral
(2,565 Views)
thanks a lot for your solutions,i'll try them now 🙂
(2,525 Views)
