i have a prpblem in enabling webserver i get message labview webserver not running error 54 , i checked IIS Manager and www the services r running ok ..can anybody tell what might be error ,,,iam on labview 6.1 and win 2003 server.,
i have a problem in enabling webserver i get message labview webserver not running error 54 , i checked IIS Manager and www the services r running ok ..can anybody tell what might be error ,,,iam on labview 6.1 and win 2003 server.,
(2,638 Views)
If you already have IIS web server running, you need to run the LabVIEW web server on a different port to avoid conflicts. It probably won't start because the port 80 is already in use.
Check options.."Web Server: Configuration" within LabVIEW.
(2,638 Views)
