need help on FFT
IS there anybody who can help me to verify a FFT result?
I 'm translating a program from ASYST to labview.
I got result different from the old program. could you please make a small labview program to do FFT to the data i attached and see what is the FFT outcome? I want to verify my result. thanks!
(2,822 Views)
please see attached files...
It is for LV 6.1, couldn't convert it to LV 6.0
Same FFT result was obtained when using FFT from ORIGIN 7.0
BTW, if you mistrust the FFT algorithm, why not synthesize a simple analytic
waveform (like a rectangular pulse) and compare the numerical result of LV's
FFT with the analytic solution?
-Franz
"fenny" schrieb im Newsbeitrag
news:50650000000800000012910000-1042324653000@exchange.ni.com...
[Att
achment fft.vi, see below]
(2,822 Views)
