i have an error occurred when i try to print from LabVIEW
an"error -2147352567 occured at failed to get a printer information" eventhough everything is ok.if somebody can help me with that.
Thank you.
file attached.
(2,522 Views)
The printer name was probably misspelled.
I’ve changed your vi to print to the default printer and it seems to work fine…
(2,505 Views)
