Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
i have an error occurred when i try to print from LabVIEW
b_rani
Member
05-31-2005
07:26 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
an"error -2147352567 occured at failed to get a printer information" eventhough everything is ok.if somebody can help me with that.
Thank you.
file attached.
50 HZ FFT2 Print.vi 234 KB
0
Kudos
Message
1
of 2
(2,520 Views)
Reply
Re: i have an error occurred when i try to print from LabVIEW
Jonas Van Otterdijk
Member
05-31-2005
10:12 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
The printer name was probably misspelled.
I’ve changed your vi to print to the default printer and it seems to work fine…
50 HZ FFT2 Print_2.vi 231 KB
0
Kudos
Message
2
of 2
(2,503 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
