i have conected webcam with myrio and i found following error.please suggest what is the error..
Hi sagar,
please read and follow the error message! Did you ensure the library is available on your RT target?
Is it even capable of running IMAQ libraries?
Next time please use a more descriptive header line and more text in the message!
Message 2 of 18
(4,727 Views)
the imaq libarary is there in ni  max. and the files which is mentioned in error also  there in folder where i installed labview.than what is the problem.i am attaching ni max snapshot
Message 3 of 18
(4,706 Views)
You need to install the IMAQ components to the myRIO not your computer. Expand 'Remote Systems', find your myRIO, click software and then 'add/remove software' and install the 'Vision Features' to the target.
(blog)
Message 4 of 18
(4,693 Views)
ok..so i have installed imaq on computer but not on myrio.so sir howcan i install vision feature on myrio from where i could get.sir i am new on myrio so have not basic ideas.
Message 5 of 18
(4,686 Views)
Did you read my post at all?
"Expand 'Remote Systems' (in MAX), find your myRIO, click software and then 'add/remove software' and install the 'Vision Features' to the target."
(blog)
Message 6 of 18
(4,675 Views)
ok..sir thank you..if further queries will there than i will ask u.thanks a lot.
Message 7 of 18
(4,667 Views)
hello sir..i am now facing following error.please guide me
Message 8 of 18
(4,621 Views)
Does the camera show up in NI MAX under your myRIO?
It should appear in the list like this (I don't have a camera on my cRIO - but this is where it should appear):
The name of the camera (e.g. cam0) is what you should specify in your LabVIEW code. Post your LabVIEW code if you are having further issues.
(blog)
Message 9 of 18
(4,607 Views)
yes sir camera is working well in ni max .only not running in vi
Message 10 of 18
(4,596 Views)
