i have conected webcam with myrio and i found following error.please suggest what is the error..
oh..sorry sir..under myrio it is not showing...in pc only it is showing
Message 11 of 18
(1,898 Views)
Did you connect your camera to the USB port of the myRIO?
(blog)
Message 12 of 18
(1,884 Views)
actully currently i am using my laptop webcam sir.
Message 13 of 18
(1,880 Views)
can it work with laptop webcam sir...?
Message 14 of 18
(1,873 Views)
Hi sagar,
so the webcam is NOT connected to your myRIO, but you expect the myRIO to detect it?
Similar question: do you have access from your laptop to a webcam in your collegues computer? Think about it…
Message 15 of 18
(1,862 Views)
so sir is there any way that i can use my laptop webcam under myrio or i must have to purchase a usb webcam?
Message 16 of 18
(1,843 Views)
You could write two LabVIEW programs, one on your computer that accesses the webcam and makes the images available over TCP/IP or some other remote access means and the other on your myRIO that reads the images over the remote access connection from the first program. If this sounds complicated to you then you might be right but it is doable.
But the cheapest solution definitely will be to buy an USB webcam. They can be bought for less than what 10 minutes of work time of anyone who has participated in this thread to help you would cost.
Rolf Kalbermatter  My Blog
Message 17 of 18
(1,817 Views)
ok...thank u all for your very helpfull support.thanks s lot.
Message 18 of 18
(1,795 Views)
