i have to creat a password login ,but the password should be saved in .ini fie in encrypted form
i want to make a sbvi . while running this subvi a dialog box open. enter the password
the password is saved  in .ini file and is in encrypted form.
there is other option in dailog box that modify password
in tht
old password
new password
confrim new password
this password also stored in the same .ini file in encypted form.
(3,221 Views)
Hi ezeemon,
either you write your own encryption vi to hide the password in the ini file or you may look for "blowfish" here in the forum...
(3,213 Views)
Hi ezeemon,
an other way could be to generate a hash value of your password and write this into the ini file. The next time you will check the password you genereate the hash of the input and compare this with the hash from the ini file.
Mike
(3,204 Views)
There is an OpenG vi 'MD5 Digest' that takes a string input and returns a hash value.
Matt
(3,184 Views)
