i need to plot 6 arrays on the y axis and one on the x axis
i need to plot 6 arrays on the y axis and one on the x axis.
The XY graph would show 6 lines of data points plotted against one array wich would be my x axis.
All arrays are the same size.
for example monitoring voltages on 6 devices over temperature.
voltages would be the y scale and temperature would be the x scale.
i know you can plot multiple wave forms in a waveform graph.
When I use the xy graph it only shows one line.
i believe it can be done because it the properties menu there's an option to show multiple plots.
PS excuse the bad drawing I attached.  Smiley Happy
(2,769 Views)
XY graphs take data in many forms.
In your case, you create one plot bundling x and y1. To make multiple plots, just create an array of such bundles as in this image.
Check the online help and example finder for more variations of the theme.
Message Edited by altenbach on 02-18-2007 12:48 PM
(2,757 Views)
Thanks for the info altenbach.
That worked great.
(2,730 Views)
