i want to access the database with user name and password without con. info/udl
hi to all,
im doing project related with database... normally i'll connect ***.udl file to open database.vi.
now what is my question is I want to open the database with the user name with password.... y i need this because once i run the program the program should ask username and password to open database for write/read operation. if its wrong user name and password means program should be denied...
can any tell how to access the database toolkit with the username with password....
im using labview 7.0...
i think my question is clear....waiting for reply thank you in advance...
pls see this attachment.....
N. Srinivasan
(3,363 Views)
(3,346 Views)
i have already read that link in the discussion forum...but im still have some confussion in... i attached file is so like to give user name and password..?
and one more things can tell wat to do in ODBC and MDB and in UDL for password lock.. each time i run the promgram it should ask password to acces the database..
 thank you a lot for your reply..
it will be more more useful if u clear my doubts clearly.... Smiley Indifferent
N. Srinivasan
(3,330 Views)
no response...!!!! Smiley Sad
N. Srinivasan
(3,306 Views)
