i want use google map api in VI . i tried so mutch to do it.i used google earth plugin and google static map but i need only google map api .
You did a really good job from .NET library.
I wrote some VIs to import gpx files and display it on the map.
I used the GPX functions from .NET library to read a gpx files (recorded with mymaps on Android) and the first version of your project.
2 visualisation mode:
- One color with start and End Marker
- Auto color with 5 levels depending on elevation and Start and End Markers.
Open GPX.vi, choose gpx file, select auto color or not then run the VI.
I add a new VI to read GPX files and I created a modified version of subVI :GMap.NET.WindowsForms.GMapRoute (SubVI)-->GMap.NET.WindowsForms.GMapRoute GPX (SubVI)
Maxime R.
  CLA - Certified LabVIEW Architect / Architecte LabVIEW Certifié
  CTA - Certified TestStand Architect / Architecte TestStand Certifié
Message 51 of 134
(4,040 Views)
Dear Maximer
I've reviewed your VI. It was very interesting.
M.Garousi
Message 52 of 134
(4,032 Views)
Hi Everybody,
Thank you for your intersting topic.
I have a problem with running the code :(. Error 1172 occurred while executing the code.
After inspecting I realised that I have a problem with "GMapControl" in "Create Map" SubVI. So I decided to define another ".Net Container" that point GMapControl But again I faced with another issue that says "Error inserting Activex or .Net object".
would you please tell me what is it problem for?
P.S:I have used Labview 2011 Running on Windows 7 X64
Message 53 of 134
(4,020 Views)
Finally, I've found it Smiley Very Happy
Using Labview 64 bit caused the problem.
Message 54 of 134
(4,013 Views)
Smiley Very Happy
M.Garousi
Message 55 of 134
(4,006 Views)
This is a very usefull for my ground system. Thank you for uploading.
can you include the code to save the images/tiles in the cache/folder and use when internet connection is not available for offline browsing
Thank You.
css
Message 56 of 134
(3,982 Views)
HI
It is possible. I'll add this in the future. But if you hurry you can get help from here.
http://www.codeproject.com/Articles/32643/GMap-NET-Great-Maps-for-Windows-Forms-and-Presenta
M.Garousi
Message 57 of 134
(3,978 Views)
Hello.
How can I change markers' color to my wanted? Here is only red and green markers, yes?
Message 58 of 134
(3,933 Views)
use this project and xcontrol : http://www.4shared.com/rar/aj8vN8WZ/Gmap_Xcontrol_New.html
copy logo.png in c:\windows then use project
in this Xcontrol you can use very Icon
M.Garousi
Message 59 of 134
(3,916 Views)
Thank you M.Garousi.
I've downloaded the file, but now I have an error. Please look at this picture. How can I solve this problem?
Message 60 of 134
(3,905 Views)
