i want use google map api in VI . i tried so mutch to do it.i used google earth plugin and google static map but i need only google map api .
Hi Garousi,
thank you for your reply. I just have this demo, but I need this feature in labview. How Is it possible?
Regards
Nino
Message 82 of 134
(3,494 Views)
Hi M.Garousi
   I used your VIs in my project. They all work very well when debugging.I created installer(Build specifications->installer) files and setup the specification on another computer which is not installed LabVIEW software .But when I ran the application ,an error occurred.The error is“The VI can not be executed.You must use the LabVIEW with full version to solve the error”. Can you tell me why this error occurred and how to solve it.
Looking forward to your replay.Thank U^_^
LabVIEW 2009
windows XP professional  SP3
It would be appreciated if anyone else can help me to solve the problem.
error when run:
used SubVIs
License Manager:
Message 83 of 134
(3,461 Views)
Hi M.Garousi
I used yor VIs in my project.but when i try to use it in web publishing tool i get an error.
can you help with that.
use labview 2012, win7
thank's.
Message 84 of 134
(3,168 Views)
Hi JTAG
Please check the following three
1) Please copy Logo.png files in the Windows folder
2) Make sure you use the correct Dlls.
3) make sure. Net frame work is installed on your system.
M.Garousi
Message 85 of 134
(3,048 Views)
hiii,
        I am unable to use gmap.zip file .please help me.Can i use the above zip file with internet connection
Message 87 of 134
(2,858 Views)
I am facing above problem
Message 88 of 134
(2,857 Views)
Hi all,
I've downloaded the last version posted by Garousi but it doesn't work (see attachment).
Anyone else have this problem?
Message 89 of 134
(2,830 Views)
Hi
Please copy Logo.png file in windows folder
M.Garousi
Message 90 of 134
(2,797 Views)
