iUSBDAQ HYTEK help needed
Microcontroller-encoder---transmitter------receiver----decoder---Hytek iUSBDAQ (this is my circuit)
I have an iUSBDAQ HYTEK that is connected to a receiver.The receiver is continously receiving data one byte atfer the other from a transmitter that is connected to the microcontroller.I am successfully able to read the Digital I/O byte however i am not being able to differentiate between one byte and the other.I need to connect the VT pin of the receiver to the HYTEK so that each time there is a trigger it will read the data.Can i use the trigger pin for Digital input? is there any subvi that will allow me to wait till a change of state of a certain pin so that i can upon this ask the hytek to read the write byte. The problem is it s always reading the first byte that is sent because nothing is telling the hytek that another byte has came. each time my microcontroller sends a byte via a encoder-transmitter than receiver-decoder i want to be able to read these bytes one after the other without possible overwriting cause i have 14 sensors.
i appreciate any help and thank you. any links...pointers or advice will do:)
Message 1 of 14
(6,428 Views)
Thank you but this doesn t really solve my problem. thanks anyway.
Message 2 of 14
(6,397 Views)
Hi mandya14
I searched on Google and have found this website of the manufacturer of your card: http://www.hytekautomation.ca. However, I am not sure what does it have to do with LabVIEW - are you using LV drivers (http://www.hytekautomation.ca/USBDAQ_API.aspx?productId=7) to program the acquisition with your device? If yes, then I would adivce to ask Hytek for support, since the drivers must have been done by them. We can support only devices and drives done by National Instruments - please see here: http://www.ni.com/dataacquisition/
Kind regards
Message Edited by Maciej Antonik on 05-25-2010 04:12 AM
Maciej Antonik
National Instruments Poland
Message 3 of 14
(6,379 Views)
Dear Maciej Antonik:
Thank you for replying.Yes i am using HYTEK aytomation. If you check the website there are iUSBDAQ drivers for labview and subvi for opening a session...reading from digital inputs etc. I already bought the product and it s reading perfectly fine but like i explained...there is no trigger line for DIO i think the input trigger line is for the analog only.
I have already followe ur suggestion and sent an email to the support. but still no replies. Lets hope they will reply soon.
thank you again
Message 4 of 14
(6,369 Views)
hey every buddy!!!!!!!!!!!!!!
i am the new user of hytek IUSBDAQ-U120816 data acquisition device.
so anyone help me how i interface this daq to labview and how i control it through labview for programming and other source........
please anyone explain it to me briefly....
and when i install its driver which i downloaded from its hytekautomation site which is install complete then IDAQtest&log 3.1 software appear on my destop and when i connect the device to this software then green led become on but i don't understand on his proper method so anyone provide me any vedio who use this usbdaq otherwise provide me brief documents on it........
i will be wait for reply.......
please help me plzzzzzzzzzzzzzzz.....................
Message 5 of 14
(6,120 Views)
It looks like your best bet is to get help from the DAQ manufacturer to get the board up and running. Since they made the drivers to interface with LabVIEW.  Once you can communicate with the board and do simple things , then probably taking some of the free LabVIEW tutorials would be good. BUT, YOU are the one that needs to learn what the DAQ can do, for instance how the counter works on the DAQ and so forth. Just my opinion.
Alan
Message 6 of 14
(6,108 Views)
Here is a quote from the Mfg web site, It really looks like where you should start.
We provide
complete software support for our USB DAQ, including "ready to
run" test and control software, API, SDK and examples with
source code for many programming languages such as C/C++,
C#.net, LabVIEW LLB, VB etc.
Message 7 of 14
(6,099 Views)
hey sir!!!!!!!
sir i install its driver completly and when i connect IUSBDAQ to my computer then the led will be become on in the device and it show its ready but when i want to work on it so i don't manage it........sir if you used it before so you make your own vedio of operating daq and interfacing with labview with detail and upload it on the youtube or send it 2 me which help me on the beginning of this daq other wise complete operating document send to me which help...............
please sir i will be waiting for your response,,,,,,,,,,,,,,,,,,,,,
Message 8 of 14
(6,082 Views)
You really need to follow the advice given above. The vendor has documentation and LabVIEW examples available for download as well as a support email.
One other suggestion is to skip all of those extra exclamation points and periods in your email to the vendor and instead provide some details on the example you are having problems with.
Message 9 of 14
(6,071 Views)
hello sir!!!!!!!!!
 sir i have problem please help me on this to overcome on this problem.....
because i am new user of labview due to which  this problem is occure...
........the problem is that i want to set my first DIO for 10sec and automatically it become reset &when it become reset at the same time my second DIO become active for 5sec and then it again reset and the first again set and the process is goes on........
so how i insert the time automatic set and reset option in any DAQ using..........
please provide me some information to overcome on this problem.........
............please help me..........
Message 10 of 14
(5,903 Views)
