Combine 2 1D array into 1D array with same size
Hi!
I  has tried to combine combine 2 1D arrays into 1D array with same size
But the result is not as my expectation
So please help me!
Example:
Array 1      Array 2
1                A
2                B
3                C
Expected Array
1A
2B
3C
(2,510 Views)
You are best off posting the code showing what you have tried so that we can point out where you have gone wrong. (Post your actual VI not a screenshot)
You are basically going to want both of your starting arrays to be arrays of strings. Iterate through them in a loop where you concatenate them together.
(2,472 Views)
Here is my code. It is so messing.
I has tried to combine multiple 1 D arrays  into 1D by using Loop with concatenate string as below.
However, it seem not work as well for me.
(2,459 Views)
attached code
(2,458 Views)
Can you save your code for 2019 or earlier (File/Save for previous version). Alot of us are always at least a year behind the latest version of LV
Can you also attach a copy of the data file that you are reading as it looks like a lot of your code depends upon how that is formatted.
(2,450 Views)
@KaSS90 wrote:
attached code
Your code and attached image have nothing obvious in common with your question. You need to be more specific.
(Still, your attached code is extremely questionable: too many useless sequence structures. An event structure hidden deep inside other structures. Lots of Rube Goldberg code, especially with array operations, etc. You really should go over this with someone more familiar with LabVIEW)
Example:
Array 1      Array 2
1                A
2                B
3                C
Expected Array
1A
2B
3C
To answer your original question, here's one possibility ("concatenate strings" inside a FOR loop):
(2,409 Views)
