subVI error
I try to measure the vibration of the cutting tool in CNC turning machine but when I try to run my program in the labview an error occur. The error is: ( The subVI is not executable. You must fix all errors in the subVI before this VI can run.). How can I fix it?
(1,638 Views)
Without seeing the VI (attach the actual VI, not a picture of it), we cannot tell you how to fix it.  If you have many VIs, and especially if you have them all as part of a LabVIEW Project file (.lvproj), you should compress the folder that contains all of them and attach the resulting .zip file.  Also, please tell us the name of the sub-VI that is generating the error.
Bob Schor
(1,606 Views)
"DAQ assistant" is typically an express VI that is part of DAQmx so it looks like something is corrupt. We probably need a bit of backstory.
  • Who wrote the program?
  • Are you running this in the development environment or as a standalone executable?
  • Was it ever working before?
  • What changed since the last time it worked (new LabVIEW or driver version, new computer, new configuration, new CNC machine, windows update, etc.)
(1,592 Views)
