ignore parity error
Hi
is there a property available to ignore the parity errors in LabVIEW/Visa for example docklight software has the ability to do this.
I'm testing an RS485 port from a product and the below settings were required to perform the test
(2,683 Views)
I guess you could write some code to ignore it.  I'm guessing LabVIEW will return a specific error code and then you can handle it by swallowing it.
Bill
CLD
(Mid-Level minion.)
(2,658 Views)
As Bilko said you can do this:
=== Engineer Ambiguously ===
(2,650 Views)
The error is generated with the Read function from VISA so since the error is generated I cant read the Data properly, Cleaning the error will not help for this case.
I think I will talk with the product owner and tell him it is wrong to have parity error in his product. if he want to use the  even parity option I think the products needs to be improve to remove the parity errors (I think it is a firmware issue).
(2,648 Views)
Usually when I see parity or framing errors, it is due to cabling issues (noise getting on the lines).  So you may want to check your wiring for proper shielding, pairs are properly twisted, etc.
(2,645 Views)
Luis,  when the parity is incorrect, LabVIEW is replacing the received character with the "error replacement character" which happens to be 0.
You can turn off this behaviour by modifying the visaconf.ini file in C:\ProgramData\National Instruments\NIvisa
The key for this is:
[ASRL-RSRC-ALIAS]
DisableErrorReplacement=1
Have fun.
0xDEAD
(2,640 Views)
