iir filter implementation in labview fpga
I created a simple RC-(CR)2 IIR filter using DFD toolkit, and using “DFD fpga code generator.vi“, I generated a filter core to be used in my fpga vi. My problem is that the generated core is too slow for my fpga application. I found that the ratio of ”the sample frequency/fpga clock“ returned by the code generator vi is  about 0.1. This means that the throughout for my 60 MHz fpga clock is 6 MHz, which is too much lower for my fpga application. Are there simple ways to increase the sample frequency that the filter core can handle?
I tried with several filter structures without much improvement in throughput. I know that the throughput of FIR filter can increase by means of using more pipelines stages.
What about the IIR filter?
Thank you in advance.
(3,005 Views)
You could try using the Xilinx IP: http://zone.ni.com/reference/en-XX/help/371599M-01/lvfpgahelp/fpga_xilinxip_descriptions/
They can go faster.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(2,988 Views)
