01-11-2010 08:55 AM
Hi im trying to open a locked (published) vi from labview 7.1 in 8.6 and 2009. I get the error message below. will I need to get an opened version of the vi.
01-11-2010 08:58 AM
01-12-2010 04:05 AM
Dear Ross,
Im afraid that smercurio_fc is correct. You must have a backup of the original VI to recover the block diagram.
There is plenty more info on the issue found here...
http://digital.ni.com/public.nsf/allkb/FEE732F4B1541B9586256BF0006A78CA?OpenDocument
Incidentally, "remove block diagram" is a legacy feature of LabVIEW. It is a little before my time, but I believe LabVIEW 7.1 was the last version to have this feature.
Thanks for your time,
01-12-2010 04:39 AM
RER wrote:Incidentally, "remove block diagram" is a legacy feature of LabVIEW. It is a little before my time, but I believe LabVIEW 7.1 was the last version to have this feature.
You can still remove both front panel and block diagram. To do this you have to make source distribution in project explorer. But my advice is. DO NOT DO IT. Use password instead. But NEVER password your "master copy" of your code 😉
01-12-2010 10:45 AM
Thanks guys
I was on to festo and they sent me a new copy. Ye waste no time responding. Thanks a million.
Cheers Ross
