image animation
hiii all
i need to move an object with respect to its roll pitch and yaw data ... i am getting the data from serial port.... and its working fine .. now i need to move any image in labview on basis of these values.... i was able to draw a rectangle in 3D picture ..but i dont know how to make it move as i required....
the object can be anything ....
Regards
Message 1 of 10
(5,370 Views)
hi nolsqn,
  Have you used any transformation Vis in 3rd picture control pallette?
Thanks and regards,
srikrishnaNF
Srikrishna
Message 2 of 10
(5,361 Views)
FOr some ideas, have a look at the solarsystem.vi example in the example finder.
Message 3 of 10
(5,357 Views)
Accepted by nolsqn
as said above, you can do as below
 just change the values
regards,
Message 4 of 10
(5,355 Views)
i have seen the tranformation vi's but was not able to understand them to the point that how to use them. i will have a look at solar system.vi and wil get back at you
thnx
Regards
Message 5 of 10
(5,342 Views)
HI shret...
can you save the vi u have attached in 8.5
as i m using this version
regards
Regards
Message 6 of 10
(5,340 Views)
hi altenbach
i dont seem to have solarsystem.vi in my examples.... i m using labview 8.5  but its not in my examples
Regards
Message 7 of 10
(5,339 Views)
Search for "3D", then it's the third example from the bottom of the list.
Message 8 of 10
(5,335 Views)
i finaly got it to work...
thnx all
Regards
Message 9 of 10
(5,316 Views)
below is 8.5 vi
Message 10 of 10
(5,294 Views)
