image segmentation using labview
hello, am doing my project in the title called "labview based brain tumour length and area measurement" but while am doing in image segmentation using k-means segmentation i cant get the segmented image so i need  help
Message 1 of 8
(6,327 Views)
Accepted by topic author Nardimes
Message 2 of 8
(6,290 Views)
thanks for ur replay but am doing this project in brain tumour detection so k-means segmentation must cluster out the tumour part since it is more brighter than the other side in mr image
Message 3 of 8
(6,230 Views)
I understand what you are trying to do.
You are using the k-means.vi from the MLT in segmen.vi ‏29 KB
it looks like you are having trouble to set it up properly -
the link I posted in my previous post contains a working example using exactly that k-means.vi including example images.
How about you post a typical example image of your application?
Message 4 of 8
(6,195 Views)
am using MR image
Message 5 of 8
(6,182 Views)
how can get segmented image i attached block diagram
Message 6 of 8
(6,139 Views)
sir please help me it doesnt display segmented image
Message 7 of 8
(6,131 Views)
@Nardimes wrote:
am using MR image
Hi Nardimes,
you force me to guess what you want to do.
It is pretty likely, that you want to segment the bright pixels - which I suppose to be a tumor (foreground) - from the rest of the image (background)
If that is the case, this is a non-trivial task to do.
This is because in both images  those tumor-grey-values  occur in more than one region.
You need to choose a different segmentation approach,
or introduce more steps in your image processing, e.g.
distinguish between object and no-object pixels,
define a region of interest with-in the ovject pixel-region.....
I can not help you with that
Message 8 of 8
(6,114 Views)
