image selector according of the configuration of an input
How are you addressing the PLC? What do you see out of the PLC? Is each letter (ABCDEF) a word that you are reading?
This will make a difference how you put together your code.
Tim
GHSP
Message 11 of 24
(837 Views)
No, I see only booleans, 0, 1 , acordind to this configurations it would show a diferent image.
I have anothe doubt, What if I want to use the value of one indicadore twice or more times?, I'm creatting a local variable, But when I want to use this value again the proyect actue wrong.
Message 12 of 24
(833 Views)
This confuses me - In LabVIEW booleans have values of TRUE or FALSE.
0 and 1 are integers, or possibly floating point numbers, but not booleans.
Steve Bird
Culverson.com
LinkedIn
Message 13 of 24
(830 Views)
You should avoid local variables, until you are experienced enough to know what they can and cannot do to/for you.
Have you looked at the example programs provided with LabVIEW?
A lot of basic concepts are covered in there.
Steve Bird
Culverson.com
LinkedIn
Message 14 of 24
(827 Views)
Are your inputs going to a daq card so they are digital inputs or are you reading them from another device?
Tim
GHSP
Message 15 of 24
(826 Views)
I take the variables from an OPC server. It will be digital outputs from the PLC
Message 16 of 24
(823 Views)
No, where can I found those examples??
Message 17 of 24
(821 Views)
Do you have sucessful communications with your PLC through the OPC?
Tim
GHSP
Message 18 of 24
(819 Views)
YES. with RSLINX and SLC 5/04 PLC
Message 19 of 24
(814 Views)
Are you reading out one word or is this many words from your PLC?
Do you read one Boolean word that has 8 bits so you get an array of Boolean values?
How is the data presented in LabVIEW?
Tim
GHSP
Message 20 of 24
(812 Views)
