image to array
Hello
I am trying to imput an image to labview, then convert it to array and then convert the array to spreadsheet string. I was trying to do it using NI example for imagetoarray, but i cant. can you help me with some hints or a sample code please
Message 1 of 17
(7,108 Views)
Accepted by Ariadni
Maybe this will help. You have to select the image type you have. U8, I16, etc.
The Enrichment Center is required to remind you that you will be baked, and then there will be cake.
Message 2 of 17
(7,093 Views)
Thanks very much it was very helpful
Message 3 of 17
(7,081 Views)
Hello again,
How can i convert an image now from array to image? actually i want to use the labview code that you have provide me to convert an image to array and then send it using zigbee modules. I have establish the communication between the two modules but how i can take the image from the receiving module and convert it back to image and then preview it.
Thanks in advance
Message 4 of 17
(7,070 Views)
I added to the example, hope this helps.
Message 5 of 17
(7,057 Views)
Hello its very helpful this.
I have attached the code that i am trying to produce. But i dont know how i can connect your code to mine. My code is about transmit string wireless (using zigbee modules). I have checked it and work when i am trying to send characters. How i can connect it to your code in order to select an image preview it convert it to array send this array to another laptop and then convert this image to array and preview it.
Thanks in advance
Message 6 of 17
(7,051 Views)
Does this help?
Message 7 of 17
(7,045 Views)
Thanks again for your valuable help.
When i run it on laptop A ( that is connected with ZigBee A) it works. But laptop B (connected with ZigBee B) ask me to give a path in order to import an image. What i can do for this?
Message 8 of 17
(7,041 Views)
It looks like you have to copy the picture from laptop A to B before executing the program on B.
Message 9 of 17
(7,035 Views)
But if I copy it I dont send it. My target is to send the array and then convert it to image. Can I achieve this?
Message 10 of 17
(7,033 Views)
