implementation of time triggered events
imagine ive got a schedule to turn on and off many leds at a givent time of day as attached. (col 3=on  time, col 4 = off time).
whats the best way to implement this?
an event case firing events at given timestamps? (ive already converted strings to timestamps)
2 event structures (one for the on and one for the off times)?
a while loop with 1s period?
a timed loop?
ps. this is going to be part of a larger project im working on. actually some serial bytes are going to be sent at every given time.
obviously i could go with a while loop ticking every second and comparing current time with my on and off timestamps, but  i can see its a waste of resources.
any ideas? thank you in advance.
Message 1 of 10
(5,876 Views)
One thing you could implement is a "Scheduler".  Suppose you need to turn things on and off with a time accuracy and precision of 1 second.  You could create a "Schedule", an Array of Clusters that contain a Time and an Action (which could be a Boolean, On/Off, and an identifier to say which control to turn on or off).  You have one routine that adds new Events to the Schedule, another that acts like a Clock, firing once/second and seeing if anything is due to be Scheduled Now.  If no, then you "go back to sleep", otherwise handle whatever needs to be scheduled.  I recommend that you do this in a parallel process so that the "clock" runs independently from the process being scheduled.
Message 2 of 10
(5,817 Views)
i've already got a kind of scheduler. my on off timestamps are stored in a multicolumn listbox for each day of the week. i just need to generate an event at given times of day without using a while loop comparing every sec my system time with the given timestamps.
wasting resources if you think that in a day i could have one or two timestamps.
any help on how to implement that?
Message 3 of 10
(5,792 Views)
came with a solution. i calculate the time remaining to nexr event and feed it to a timeout event structure. works well but im having issues when i have the same timestamp for 2 items. works if they have 1sec difference.
but given that i need to send & receive serial commands at 9600baud instead of turning on off leds i would need some sort of queue for the commands to be sent that have the same timestamps (both on & off).
any ideas? thank you.
Message 4 of 10
(5,775 Views)
I don't have LabVIEW 2016, so I can't look at your vi,
but be aware that the Event Timeout is not a reliable
timing method.
Any Event that occurs (like a button push or user Event) will reset the timer.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
Message 5 of 10
(5,768 Views)
that event structure will only have the timeout event.
i uploeaded a sc. the false case only increases the index.
any other ways to generate events at given timestamps?
im new to labview so im short of ideas. thank you.
Message 6 of 10
(5,767 Views)
I don't know how "new" you are to labVIEW - your block diagram is very
clean and organized - better than I've seen from some experienced people. Kudos.
Bob_Schor gave some very good advice earlier. I would like to add a bit to his mention
of using an Array of Clusters. If each cluster has a timestamp and an an array of
actions, you can handle those occasions where multiple events need to be performed
at the same time. Use a For Loop to process the actions.
I haven't been able to think of a way to avoid polling the timestamps for the next action(s)
but 1 one second interval should not cause any issues. I think you can do without the
Event structure.
For sending the data to your serial device, I would send the data (or request) to a
consumer loop using a queue.
You haven't said how accurate the timing needs to be. This would be useful to know.
steve
Message 7 of 10
(5,751 Views)
thanks for that. like to keep things nice and clean. been using since august.
as for timing accuracy. on a given timestamp i should send a serial command and get a response from a plc.
so two items with the same timestamp should be sent "simultaneously". obviously send second command after ive got the first response. so a queue should be useful here as you stated. one sec of a difference between the to commands is more than enough for me.
keep in mind that my "list" could have up to 20~30 items so 40-60 timestamps. so ill need to poll all of them each sec.
as for the array of clusters. if i got it right. lets say ive got 20 items. so 40 timestamps.
you mean i should create 40 clusters with a timestamp and the command to be sent. then feed them in an array and poll them each sec? obviously will be handy to sort the array by the timestamps.
Message 8 of 10
(5,734 Views)
Accepted by afetsis
Yes, I would assemble the array in timestamp order.
Then you only have to check one array entry.
When you get a match, process it and increment the array.
Here is a simplified array of clusters based on your earlier posting:
Notice how multiple concurrent actions are handled (first element). The example shows
an array of strings for the action, but it could be a cluster of items if that is useful.
Be sure to name the cluster items and "Type-Define" your clusters.
steve
Message 9 of 10
(5,725 Views)
done. my timestamps with the respective serial commads. Smiley Happy
thank you all for your help.
Message 10 of 10
(5,689 Views)
