03-27-2007 02:53 PM
03-28-2007
11:00 AM
- last edited on
12-29-2024
04:10 PM
by
Content Cleaner
Hi Shaun,
I hope you are doing well today! Depending on the size and the function of the application, you should expect to face some issues when porting the application from LabVIEW 6.0 to LabVIEW 8.2. Here is an example when upgrading from LabVIEW 8.0.x to 8.2
LabVIEW 8.2 Upgrade Issues
My approach to this situation would be to create a new application in LabVIEW 8.2 and try to manually copy the code from the 6.0 application. This would help you understand what’s going on in the application and would help you understand the functions you use as well (which would help you debug it). You should always upgrade your application to the next maintenance release or an upgrade release, whenever they come out.
Also, have you considered training for LabVIEW? We do have some resources online which could help you learn LabVIEW. We also provide instructor-led classes for LabVIEW as well.
How Can I Learn LabVIEW?
Training and Certification
