In my VIS, i just want to use one start button(that i am using already in frame number 0).but i also want to use only one break button,one continue button and one stop button for whole program .in my existing current VIS, now every frame has one break,continue and stop button.this i want to avoid, because now if in frame number 1 i make one break local variable and pass this local variable to frame 2,3,4,5,6. the same if i do with continue button and pass the continue boolean variable to frame 2,3,4,5,6.the same if i do with stop boolean and pass local variable to frame 2,3,4,5,6,every frame of the sequence will be disturbed. i would like that every frame execute when its time of execution come
s.therefore i am using sequence.but passing variables like this will effect every frame.on the other side i just want one display of start, break, continue and stop buttons on my main user interface. without effecting the program how can i achieve this?
moreover i want to display an idicator on the user interface in which frame my application is executing.whether is it in frame 1,2,3,4,5 or 6. how can i achieve this?
thanks for your help.
