in sbrio 9638
in sbrio 9638, in the FPGA vi palette there is one section user controlled I/O sample while iam these node in sbrio its not working....
you can check below
those not are not supporting getting a error
(119 Views)
Hi Ajay,
as long as you wire an EMPTY IO resource node those methods will not work.
You need to provide a valid IO resource! (As is written in the error dialog!!!)
(110 Views)
you see here
i think these nodes will not work in sbrio 9638
you can see below image that what error i getting
(52 Views)
Hi Ajay,
Those nodes do work - you just didn't configure them correctly.
Did you even read the error explanation???
(41 Views)
