If I drop a control on the front panel, and right click
it, one of the options that appears is HMI wizard, basically the ability to associate that control with a
tag. If I associate that control with a tag, everything
is fine until I drop that control into a cluster.
At that point the control ceases to be associated with
the tag.
Similarly, if I place a control within a cluster, and
then right click on it, no HMI wizard option appears.
Therefore, my assumption that a tag can not exist
within a cluster.
This behaviour is preferrable to that of 6.01, under
this version Labview HUNG totally under the same operation. But, the current behaviour is still
not sufficient.
tb
