include a pdf to an .exe
Hi everybody !
I have a little issue, how can I include a PDF to an installable VI . ?
(4,220 Views)
1. Have the PDF in your project.
2. Add the PDF to your installer build specification
(4,214 Views)
Thanks, but, in the program ... how do I can specify the path ?
any way thanks a lot.
(4,207 Views)
What is it you're trying to do?  Why would you need the path for the pdf file in the VI?  If you're reading from and parsing a constant pdf, save yourself the hassle and just do this before you compile the executable.
Where does this need show up in your application?
(4,201 Views)
Well need it, only to open , it´s a kind of help where you can acces from the main VI, in the other case I need to open a word template to write a report of the procces. For that I need the path.
(4,194 Views)
Accepted by i.galaviz
Use "Application Directory" to get the folder of the project/executable.  From there, use Build Path to locate your PDF since your PDF should be located in a place relative to your application.
(4,180 Views)
