incorrect representation of string after receiving serial data
Hello ! i am sending serial data to my labview application from hyper terminal at baud rate of 9600 bps , i am displaying that data after concatenation at a string indicator but when i send the same character consecutively then i am not getting proper representation at the receiving side.
the screenshot of the problem is posted below.
(2,639 Views)
What other settings are you using on the serial ports?  It kind of looks like a number of stop bits difference.  Are you getting any errors?  Can you share your code?
GCentral
(2,606 Views)
Accepted by wiebe@CARYA
The problem has been solved. It was actually the connection problem from hyper terminal that was causing the issue.
(2,573 Views)
