index Array input problem
Has anyone seen this problem before.  I have an index array that I have used before in an earlier subVI but for some reason I'm getting a wiring error and I'm not sure why.  I have attached the earlier use and the current useage and I can't see why I'm getting an this wiring error.  The input is an 32bit unsign and I'm moving the lower picture function to a different program (no cut and paste).
If you have any ideas please let me know.
Gary Tyrna
(3,059 Views)
Accepted by ggaryt
Disable indexing on your array when it enters the For Loop.  As to the use of locals, give it some thought.
(3,056 Views)
Darin,
Thanks for the heads up.  I'm looking to pass the memory map information into my state machine but I'm not sure how and I have been giving it some thought.  I'm using the local to get the loop up and running (first state machine) so I'm using this as a learning platform.
Gary Tyrna
(3,049 Views)
Gary,
In general, if you're going to be passing information in a state machine from iteration to iteration, using a shift register to do this is the best choice.  If you have multiple pieces of data that need to be passed, you can use a cluster for this so that you have fewer shift registers.
Jared S.
Applications Engineering
(2,994 Views)
