indexing bundle
Included is part of my main VI.
I am trying to use a bundle to keep track of the failed tests for a pc board.  When a test fails, the test number is input into the numeric input of the case structure.
This is how I need this to work:  When a test fails, the boolean input is true, and the numeric input is the test number that failed.  I am using the property node to add one to the local variable, which keeps a running total of the number of time each test failed.  I would like the bundle to update the value of the element, corresponding to the test that failed, but it updates all values, changing all values to 0 except for the test that failed.
I think there is a way to get rid of the inside case structure (and the local variables) and just index the bundle with the top connection.
I guess if I knew how to change the numeric input to a cluster, I could input it into the top of the bundle?
Thanks for the help.
metzler CLAD
(3,976 Views)
I created a cluster of your controls and then update them based on the input from the main vi. See the attached code.
Tim
GHSP
(3,965 Views)
You will need to keep a shift register for the output cluster so that you can feed it back in on the next iteration.
Tim
GHSP
(3,964 Views)
Accepted by metzler
Here is a version that does not require a shift register. You will have to initilize this vi when you want to restart counting.
Tim
GHSP
(3,958 Views)
Great, it works nice.  I guess I don't have enough experience with bundles.
Thanks aeastet for the thorough and prompt reply.
metzler CLAD
(3,935 Views)
