indicator not updating from global file on network
A labview program is running locally but accessing a global variable on a shared network. If I view the diagram with the "lightbulb" turned on, the variable value on the diagram is changing, but the variable value on the front panel does not change. Any suggestions?
(2,326 Views)
If you set the vi property-execution to user interface, it may help
Right click on the vi icon,
select vi properties
execution- preffered execution system
(2,326 Views)
