initialize an array of clusters
I know this is simple and I've looked through many discussions as well as studied the turtorial.  I am missing something very simple.  Please tell me why the broken wire exists for both images?   In one instance the source and sink are exact?
CJ
(4,426 Views)
The 'default state' declares what the structure/elements of the cluster will look like.
You are contradicting this by what you are building into the cluster.
The two have to match.
Cory K
(4,412 Views)
The cluster array that you are building consists of a cluster that has two scalars, not two arrays. They are not exact.
(4,408 Views)
But the default state doesn't initialize the array values. This is the case for the valves state.  I am initializing the valves to False and this is an array in the default state.  What gives?
(4,396 Views)
OK, cool!  I have changed the array build to a cluster of arrays.  Am I just duplicating what is already in the default state?  How do I verify that the array values have been zero'ed?
(4,385 Views)
Your problem has nothing at all to do with the valves array. If it did, you would have a broken wire there. The problem is with cluster array - where the broken wire is. Look very, very closely at the 'default state' cluster and the elements in it. They simply do not match for the reason I already gave.
If you had posted an actual VI instead of some image, I would have posted the fix. Since you did not, CHANGE THE ELEMENTS IN THE CLUSTER to match.
(4,384 Views)
