JKI package manager and LV7.1?
Hi folks,
If this isn't the appropriate forum for this question, please re-direct me.  I'm using LV7.1 at work and home.  At home, I'm running it under Vista - I haven't run into any problems with this, but I'm not using any hardware - just writing standalone programs for number crunching type stuff.  Having recently seen the Moore Good Ideas VI packages, I decided to try installing them at home, but I can't get the required JKI Package Manager to work properly.  It recognizes the LV version and will even launch LV, but when I go to install a VI package (any package, MGI or OpenG, etc.), it just sits there with the Package Manager process indicator going endlessly (I let it run for 20 mins once).  I am sure I have the LV settings correct per the instructions.  Does anyone have experience with this combination (JKI pkg mgr/LV71/Vista) or possibly the former two with XP?  Some of the available VI packages are supposedly compatible with LV7 (and 6 for that matter), so I assumed it would work somehow - bad assumption?
Michael Tracy
Synergy Microwave
(2,487 Views)
Have you set the 'VI server settings correct'?
I had no issues on Windows XP or Windows 7 with LabVIEW 7.
Ton
My LabVIEW Ideas
(2,481 Views)
