on/off temperature control output from PID
Hi community,
I am using a cRIO system with an NI 9213 thermocouple input module to read temperature and a NI 9476 sourcing digital output module.
What I need to do is read the temperature with a thermocouple, use a PID to control the temperature set point and depending on the PID output turn on/off one of the NI 9476 outputs that will control a solid state relay to turn on/off the heater.
I read a lot about this and apparently the way to do it is with PWM. The thing is that I am new to LabVIEW (around 3 months) and I don't know how to do this. If someone could help me with this, any recommendation or something I will appreciate it.
Ferdinand Martinez
FMO Automation LLC
(7,632 Views)
This may help with your setup
PID Control Reference Example for LabVIEW FPGA
http://zone.ni.com/devzone/cda/epd/p/id/5814
Andy Chang
(7,627 Views)
