initialize control to new default value
Hi all,
I would like to initlize a control to a new default value? I was looking into property nodes and invoke node, I can use invoke node to initialize it to default but how to change the default value from within the block diagram ? is it possible even ?
Best Regards
Regards
(4,368 Views)
Accepted by nolsqn
so i jsut read this
http://forums.ni.com/t5/LabVIEW/Make-Current-Value-Default/m-p/777099/highlight/true#M355585
soo i am asssuming *ini file is the way to go
Regards
(4,363 Views)
Yes, you should use a configuration file of some sort.  I personally prefer the *.ini file type using the Configuration File VIs NI has made.
(4,358 Views)
hi Crossrulz,
I am already using that, it just poped in my mind that maybe if there is a invoke node to default the value, there might be a way to set the last value as default as well 🙂
Regards
(4,354 Views)
@nolsqn wrote:
hi Crossrulz,
There is no executable out there (other than a virus) which does that.  You have to save the configurations in an external file of some sort.
(4,351 Views)
thanks 🙂
Regards
(4,346 Views)
