initialize variable
Hello, I am new to Labview and I'm trying to modify an already existing code. The main VI is _cop_tracker.vi and one of its subVI is random_target_time_coordinator.vi. I have local variable 'Numeric3' (used as a counter) in the subVI. How do I initialize this variable to zero. ie every time I run this code how do I initialize it to zero. Thanks, -PN
(8,378 Views)
I cannot see your code (postin by phone), but a counter should be implemented with a shift register. In your case, initialize it with zero.
(8,372 Views)
Accepted by pnam
OK, now I see the subVI. Use a globally initialized feedback node, e.g. as follows.
(You also need to decide what to do when an error occurs)
(8,358 Views)
Spoiler
Thanks a lot. It worked!
(8,323 Views)
Thanks to you,
I was having the same prob. and was not known to the fact that we can intialize the feedback node.
A Kudo for thanks. Smiley Happy
(7,771 Views)
Helped me too, thanks!
(7,322 Views)
