insert new value to existing csv file
I have a CSV file which I created using a totalizer. now I need to insert string values to this by searching the row
Eg:- first column is date so I will search the date and insert comment to it
attached the CSV file
Message 1 of 19
(4,769 Views)
You will need to read the entire file, do your search, add whatever data you need to, and then rewrite the file.
Message 2 of 19
(4,764 Views)
Something like this:
Cheers
Message 3 of 19
(4,748 Views)
HI,
I tried do this but problem server PC is updating this CSV file on a time basis and client PC is displaying and exporting to excel whenever user export
Message 4 of 19
(4,734 Views)
Share you code, please.
Cheers
Message 5 of 19
(4,722 Views)
Hi
Thanks for your attention... please find the attachment
Message 6 of 19
(4,691 Views)
This doesn't really show what your problem is. You should be able to easily implement the code I put above in to this VI you attached.
It's hard to tell what you meant by your statement above, but it sounds like the file is being updated from two different places? So you're having an issue updating the file from the local PC when the server is editing it too?
Cheers
Message 7 of 19
(4,682 Views)
Hi,,
Can you give me the code which you showed I hope it will work
Message 8 of 19
(4,674 Views)
@sandy1234 wrote:
Hi,,
It's a code snippet.  Just copy it and paste it onto your block diagram.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 9 of 19
(4,659 Views)
HI,
Sorry I am not able to retrive the snipet... Its just remains as image
Message 10 of 19
(4,641 Views)
