only possible to make a measurement on the first channel of the scan list
NI-DMM/Switch Express
+ Goal of the labview programm : Automated Measurements and Switching
+ Description of the hardware configuration :
++++++PXI-4065 on slot #5 (DMM)
++++++PXI-2503 on slot #12 |(relay switych)
+ Configuration of the NI-DMM/Switch Express
+++++ switching configuration : 2-wire 24x1 multiplexer , PXI trigger synchronous , DMM measurement complete : PXI trigger 0 - scan list : PXIslot12/ch0->com0 and PXIslot12/ch1->com0
+++++ timing configuration : N sample : 10
+++++ Configuration : device : PXIslot4 (PXI-4065), Measurement function : DC volt , Specific range : 10
+ Description of the issue
++++++ 7.5 volts is connected to CH0, 8.5 volts is connected to CH1.
With NI-DMM/Switch Express the mesurement on com0 shows always 7.5 volts. The channel #1 is never switched to the com0. IT IS THE BUG --- HOW TO FIX IT ? What is missing in our configuration? software ?
Remark #1  via  NI MAX the swicth is working properly
(3,356 Views)
Code?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,290 Views)
I suspect a bug in your program.
Steve Bird
Culverson.com
LinkedIn
(3,220 Views)
hello,
You will find the code in attachment, very basic one !
1-DC signal on CH0 between CH0+ and CH0-
2- DC signal on CH1 between CH1+ and CH1-
3- Measurement on COM0 between COM0+ and COM0-
COM0 always see CH0 !
thanks for your help
(2,983 Views)
