insert space character between every two character in a string
I am trying to put a space between every two characters in an input string.  I only got the VI to work after the first 2 characters.  Can you help me get the space after every two (2) characters?
hiNi
Message 1 of 19
(11,713 Views)
Your input looks suspiciously like a hexadecimal number. Are you sure you need to be passing around strings instead of numbers?
If you really do need to work with strings, why not keep it as strings instead of converting down to bytes?
Message 2 of 19
(11,705 Views)
Message 3 of 19
(11,695 Views)
Accepted by hiNI
I was thinking more like this
Spoiler
There's an extra space at the end which can easily be deleted.
Message 4 of 19
(11,684 Views)
Accepted by hiNI
Easyer with string functions.
Ben64
Message 5 of 19
(11,673 Views)
Using \V (not vertical whitespace) adds the spaces line by line and ignores the linefeeds.
Message 6 of 19
(11,639 Views)
You can get a little more performance (>10x?) if you don't use build array in a loop and avoid regex
Message 7 of 19
(11,540 Views)
You will need to pad an extra space at the end of the original string is its lenght is odd.
Ben64
Message 8 of 19
(11,530 Views)
Ben64
Depends on what's in the requirements doc Smiley Wink
Message 9 of 19
(11,525 Views)
Just to break the monotony, here's yet another possibility.... 😄
(of course tweaks might be needed if the number of input characters is not even or if the last space is unwanted, for example)
Message 10 of 19
(11,496 Views)
